In looking at KMotionCNC I noticed that there is an override for rapids and for feed movements.
I would like to make sure I understand correctly.
1. G00 speeds are determined from data put into the step response screen
- If I increase the rapid override to 2.0 this will double the velocity, acceleration, and Jerk parameters set in the step response screen?
2. G01-02 movements are set from the trajectory planner
- Increasing the feed override will change the acceleration and velocity in the trajectory planner?
In this is the case I need to be careful if I have tuned these parameters, as increasing them could cause following errors.
Scott
